joemar
Level 4
Level 4
This script quickly creates a UCS Platform Emulator Instance on your Hyper-V host machine.
You must first download the UCSPE from communities.cisco.com/ucsm, extract the files and convert the four VMDKs to VHDs.  I use StarWin V2V Image Converter but others also work.
     http://www.starwindsoftware.com/converter
It requires Windows Server 2012 or beyond with the Hyper-V role installed to run the UCS Platform Emulator.
The Hyper-V service must be running.
You must copy the UCSPE VHDs to your Hyper-V Virtual Hard Disks default folder
You must have a vSwitch configured for use
Your workstation must be able to allocate a minimum of 1GB RAM or maximum 4GB RAM to the virtual machine.
Version Information:
     0.8.01 - First version published to communities.cisco.com
As always let me know if you have any comments, concerns, or questions!
Joe
