joemar
Level 4
Level 4
This script allows you to connect to a single or multiple UCS domains and it will take all 4 types of backups available in UCS for each domain.  The filenames will be descriptive of the UCS domain and the date/time of the backup.  The script supports interactive mode or supports the ability to run fully unattended to make it simple to use Windows Task Scheduler to take backups on a schedule.  The script is fully documented and has complete integrated help (get-help).
Change Log:
   v0.1.00 - Initially posted version
   v0.1.01 - Fixed issue when used with systems registered to UCS Central
As always, let me know if you have any questions, comments or concerns!
Joe
rafael.monteiro
Hello Joe,
Thank you for your scripts, they are verry usefull
I have a question and an issue, hope you can help
Question:
On the backup settings, are the "Preserve Identities" check?
Issue:
The Config-all is working fine
But all the others are not working and my knowledge level don't permit me to understand what is the problem
Output:
Script Running...
This script allows you to backup a single or multiple UCS domains.
It will create each type of backup available on UCS.
NOTE: UCS Platform Emulator cannot take a full-state backup
The files will be saved to folder: E:\PowerShell\UCS\BackupAll
Checking for proper PowerShell version
        Your version of PowerShell is valid for this script.
                You are running version 3.0
Checking Cisco PowerTool
        PowerTool version 0.9.11.0 is already Loaded
Enter UCS system IP or Hostname or a list of systems separated by commas: <POD Name>
Testing PING access to UCSM
        Successful access to <POD Name> by Ping
Logging into UCS
        Enter your UCSM credentials
                Logging into: <POD Name>
                        Login Successful
Removing any previous UCSM Backup configurations from UCS: <POD Name>(IP)
        Complete
Backing up UCS: <POD Name>(IP), Backup Type: config-all
Removing backup job from UCS: <POD Name>(IP)
        Complete
        Complete
Backing up UCS: <POD Name>(IP), Backup Type: config-logical
        ***WARNING*** Error creating backup: E:\PowerShell\UCS\BackupAll\UCSMBackup_<POD Name>_config-logical_9-23-2015_11-58-57.xml
                NOTE: This is normal behavior for a full-state backup on a UCS Emulator
        Complete
        Complete
Backing up UCS: <POD Name>(IP), Backup Type: config-system
        ***WARNING*** Error creating backup: E:\PowerShell\UCS\BackupAll\UCSMBackup_<POD Name>_config-system_9-23-2015_11-58-57.xml
        Complete
        Complete
Backing up UCS: <POD Name>(IP), Backup Type: full-state
        ***WARNING*** Error creating backup: E:\PowerShell\UCS\BackupAll\UCSMBackup_<POD Name>_full-state_9-23-2015_11-58-58.xml
        Complete
joemar
Level 4
Level 4
Rafael, sorry for my late reply but I'm just back from a 3 month leave.  Did you get this working?  Do you need assistance?
vmadalik
Does this Script have a way of saying - if the backup operations being performed is a success or failure at any point in time?
I have a customer with 4000 servers spread across 60+ domains and no way of finding out if the backup operation was successful/failure unless we manually access the domains.
Please advise.
VM
joemar
Level 4
Level 4
It does in that it reports to the display success or failure of each backup as seen below in this snip of the script:
    Try
   $DontShow = Backup-Ucs -PreservePooledValues -Type $UCSbackupType -Ucs $UcsName -PathPattern $BackupFile -ErrorAction Stop
   Catch
   Write-Output "    ***WARNING*** Error creating backup: $BackupFile"
   Write-Output "   NOTE: This is normal behavior for a full-state backup on a UCS Emulator"
   Write-Output ""
   Finally
   if (Test-Path $BackupFile -eq $true)
   Write-Output "    Complete - $BackupFile"
   Write-Output ""
It would be fairly simple to take the success or error and write that to a log file for each backup or do something else with it depending on your needs.  These scripts are samples/examples so feel free to take it and modify it for your needs.
