Workflow Name | Create new Device Group and Traffic Group on F5 BigIP Platform |
Description | Creates Device Group, Traffic Group and updates existing Virtual Server to be part of the new Traffic Group |
Prerequisites | Tested on UCSD 6.0 |
Category | Workflow |
Components | F5 BigIP Platform |
User Inputs | Device Group name, Traffic Group name, and selection of existing Virtual Server |
Output | None |
- Download the attached .ZIP file below to your computer. *Remember the location of the saved file on your computer.
- Unzip the file on your computer. Should end up with a .WFD file.
- Log in to UCS Director as a user that has "system-admin" privileges.
- Navigate to "Policies-->Orchestration" and click on "Import".
- Click "Browse" and navigate to the location on your computer where the .WFDX file resides. Choose the .WFDX file and click "Open".
- Click "Upload" and then "OK" once the file upload is completed. Then click "Next".
- Click the "Select" button next to "Import Workflows". Click the "Check All" button to check all checkboxes and then the "Select" button.
- Click "Submit".
- A new folder should appear in "Policies-->Orchestration" that contains the imported workflow. You will now need to update the included tasks with information about the specific environment.
F5-Traffic-Device-Grp.wfdx.zip
