jomcdono
I wrote a script for a coworker who was at a customer site and needed to collect information from every blade in every UCS in the customer’s data center. The information to be collected was
  • Server
  • Service Profile
  • Adapter Firmware Version
  • CIMC Firmware Version
  • BIOS Version
  • Board Controller Firmware Version
  • Host Firmware Policy
When I started I was looping through the blades and for each blade making a series of cmdlet calls to retrieve the information related to each blade and the script ran very slow. In fact the information retrieval for the items above resulted in 5 Get-Ucs cmdlet calls per blade.  If the UCS had 80 blades there would be 401 Get-Ucs cmdlet calls to retrieve all the information just for that one UCS.  One call to get all the blades, plus 5 times the number of blades in the system of Get-Ucs cmdlet calls (4 Get-UcsFirmwareRunning calls and 1 Get-UcsServiceProfile).  The script worked and it was good enough to get the job done perhaps if it was only going to be run once.
However it could be better, more efficient and take the number of Get-Ucs cmdlet calls from 1 + (5*#blades) per UCS domain to 3 per domain. That’s significantly better and the script will run much much faster. Think about the information that you need to retrieve and if there is a way to get more than just a single item per cmdlet call.
For the list above I know that I can get the blade dn and it’s AssignedToDn with a call to Get-UcsBlade, all the firmware information can be retrieved with a call to Get-UcsFirmwareRunning, finally the host firmware policy can be pulled from Get-UcsServiceProfile. Since I’m getting all the blades and looping through them, why can’t I also get ALL the firmware for all the blades and ALL the service profiles for all the blades and look through the retrieved objects. That is exactly what I did and resulted in the script below.  I am filtering the results of two of my cmdlet calls, which is ok, but you could get all the firmware and all the service profiles, the script would still produce the same results, it just might run a slight bit slower.
<# .SYNOPSIS
Ucs-Blade-Info, get blade info from one ore more UCS Domains and output as CSV .DESCRIPTION
Ucs-Blade-Info, get blade info from one ore more UCS Domains and output as CSV .NOTES
John McDonough, Cisco Systems, Inc. (jomcdono) .PARAMETER Ucs
The UCS hostame or IP address .PARAMETER UcsUser
A UCS user name .PARAMETER UcsPass
The user's password .EXAMPLE
Ucs-Blade-Info.ps1 -Ucs "10.10.20.30" -UcsUser admin -UcsPass admin123Ucs-Blade-Info.ps1 -Ucs "10.10.20.30,10.10.20.10" -UcsUser admin -UcsPass admin123 #>
param(   [Parameter(Mandatory=$true,HelpMessage="Enter a comma separated UCS hostname or IP address list")]     [string] $Ucs,   [Parameter(Mandatory=$true,HelpMessage="Enter UCS user")]     [string] $UcsUser,       [Parameter(Mandatory=$true,HelpMessage="Enter UCS user's Password")]     [string] $UcsPass
# Connect to UCS System
  Import-Module CiscoUCSPS -ErrorAction SilentlyContinue   Set-UcsPowerToolConfiguration -SupportMultipleDefaultUcs:$true > $null;
  $password    = convertto-securestring -Force -AsPlainText $UcsPass;
  $credentials = new-object -typename System.Management.Automation.PSCredential -argumentlist $UcsUser,$password;
  $ucsms = $Ucs.Split(",");
  Connect-Ucs  $ucsms -Credential $credentials > $null;
  "UCS,Server,Service profile,Adapter firmware,CIMC firmware,BIOS,Board controller firmware,Host firmware policy";   $Firmware         = Get-UcsFirmwareRunning -Filter "dn -ilike sys/chassis-*/blade-*";
  $ServiceProfiles = Get-UcsServiceProfile -AssocState associated;
  $Blades             = Get-UcsBlade;   $Blades | %{     $Blade  = $_;     $AdapterFirmVer     = $Firmware | ?{$_.dn -like $($Blade.dn + "/*") -and $_.Ucs -eq $Blade.Ucs -and $_.Type -eq "adaptor" -and $_.Deployment -eq "system"} | Select-Object -ExpandProperty Version;
    $CimcFirmVer        = $Firmware | ?{$_.dn -like $($Blade.dn + "/*") -and $_.Ucs -eq $Blade.Ucs -and $_.Type -eq "blade-controller" -and $_.Deployment -eq "system"} | Select-Object -ExpandProperty Version;
    $BiosVer            = $Firmware | ?{$_.dn -like $($Blade.dn + "/*") -and $_.Ucs -eq $Blade.Ucs -and $_.Type -eq "blade-bios"} | Select-Object -ExpandProperty Version;
    $BoardControllerVer = $Firmware | ?{$_.dn -like $($Blade.dn + "/*") -and $_.Ucs -eq $Blade.Ucs -and $_.Type -eq "board-controller"} | Select-Object -ExpandProperty Version;
    $HostFirmWarePolicy = $ServiceProfiles | ?{$_.dn -eq $Blade.AssignedToDn -and $_.Ucs -eq $Blade.Ucs} | Select-Object -ExpandProperty OperHostFwPolicyName;     $Blade.Ucs + "," + $Blade.dn + "," + $Blade.AssignedToDn + "," + $AdapterFirmVer + "," + $CimcFirmVer + "," + $BiosVer + "," + $BoardControllerVer + "," + $HostFirmWarePolicy;   }   Disconnect-Ucs;
  Set-UcsPowerToolConfiguration -SupportMultipleDefaultUcs:$false > $null
Hope this helps.
5 Comments
victor.trapala
Community Member
Is there any existing ps1 script to get warranty status of an entire UCS domain?
jomcdono
What do you mean by warranty status? Licensing?
I can tell you that any data/information that you see in the UCS Manager interface is retrievable by a script.
There is a PowerShell library for UCS called UCS PowerTool that allows for any information in the UCS interface to be retrieved and managed.
John
victor.trapala
Community Member
I mean to validate the warranty (hardware) status on the whole environment for support purposes, more specifically, blades, IOMs, Fabric Extenders
jomcdono
Warranty information is not stored in the UCS, however you can run scripts to pull the serial numbers for the components you listed.
The UCS PowerTool guide has examples on how to retrieve data from the UCS components.
For example to retrieve blade serial numbers use the Get-UcsBlade cmdlet and select the desired information.
PS C:\> Get-UcsBlade | Select-Object Ucs,Dn,Serial | Format-Table -AutoSize
Ucs    Dn                    Serial
g05-sw sys/chassis-1/blade-1 FCH153672ZG
g05-sw sys/chassis-1/blade-2 QCI1413A5IF
g05-sw sys/chassis-1/blade-3 FCH153674BA
g05-sw sys/chassis-1/blade-4 FCH153971BX
g05-sw sys/chassis-1/blade-5 QCI125200JC
g05-sw sys/chassis-1/blade-6 QCI125200K8
g05-sw sys/chassis-1/blade-7 QCI1403A5FE
g05-sw sys/chassis-2/blade-1 QCI133400F8
g05-sw sys/chassis-2/blade-2 QCI133200L9
g05-sw sys/chassis-2/blade-3 QCI133400F7
g05-sw sys/chassis-2/blade-4 QCI133601U3
g05-sw sys/chassis-2/blade-5 QCI133200GW
g05-sw sys/chassis-2/blade-6 QCI133200G1
g05-sw sys/chassis-2/blade-7 FCH1719J6EV
g05-sw sys/chassis-2/blade-8 FCH1719J6X4
g05-sw sys/chassis-3/blade-1 FCH153478UC
g05-sw sys/chassis-3/blade-2 FCH153674RA
g05-sw sys/chassis-3/blade-3 FCH153870HK
g05-sw sys/chassis-3/blade-4 FCH153870BL
g05-sw sys/chassis-3/blade-5 FCH1536740U
g05-sw sys/chassis-5/blade-1 QCI133400BM
g05-sw sys/chassis-5/blade-2 FCH163770QC
g05-sw sys/chassis-5/blade-5 JAF1503AMEJ
g05-sw sys/chassis-5/blade-6 JAF1503BQSP
g05-sw sys/chassis-5/blade-7 JAF1503BQSS
g05-sw sys/chassis-5/blade-8 JAF1503BRAM
For Fabric Interconnects
PS C:\> Get-UcsNetworkElement | Select-Object Ucs,Dn,Serial | Format-Table -AutoSize
Ucs    Dn           Serial
g05-sw sys/switch-A SSI12480267
g05-sw sys/switch-B SSI12480261
For Chassis
PS C:\> Get-UcsChassis | Select-Object Ucs,Dn,Serial | Format-Table -AutoSize
Ucs    Dn            Serial
g05-sw sys/chassis-1 FOX1252GG84
g05-sw sys/chassis-2 FOX1332HDZH
g05-sw sys/chassis-3 FOX1503GLF4
g05-sw sys/chassis-5 FOX1428GJJW
IOM
PS C:\> Get-UcsIom | Select-Object Ucs,Dn,Serial | Format-Table -AutoSize
Ucs    Dn                   Serial
g05-sw sys/chassis-1/slot-1 QCI124900BI
g05-sw sys/chassis-1/slot-2 QCI124900CL
g05-sw sys/chassis-2/slot-1 QCI133602QN
g05-sw sys/chassis-2/slot-2 QCI133602PX
g05-sw sys/chassis-3/slot-1 QCI1449A0HY
g05-sw sys/chassis-3/slot-2 FCH1603711M
g05-sw sys/chassis-5/slot-1 QCI1427A5DE
g05-sw sys/chassis-5/slot-2 QCI1427A5LR
Hope that helps
John
victor.trapala
Community Member
Thank you very much!! this was very helpful
