linksyssmartwifi.com | How do I connect to Linksys Smart WIFI?
Apollineborin
You can restore the lost configuration files from the restore option of the linksyssmartwifi.com main configuration page. To start the restoration process, you need to click the “Choose File” option and have to navigate your cursor to the location where you have saved the configuration file. Select the file and click on the Open tab to initialize the process. In most cases, the restoration process is performed after the reset or firmware update process.
0 Replies 0
