IR829 RS485 Serial port configuration
 I have just tried configuring IR829 RS485 (Modbus Serial Port) with following manual as reference,But i am getting some error related to line Propagation configuration , i have attached the Running-config and error screenshot, why i am getting this error
How to remove line "no " command is not working, how to use no form
https://www.cisco.com/c/en/us/td/docs/routers/access/800/829/hardware/install/guide/b_IR829-HIG.pdf
gauraaga
Please use the following command:
no relay line 1 1/5
no relay line 2 1/6
This will help release the lines which you can then use.
gauraaga
no relay line 1 1/5
no relay line 2 1/6
