System cpp policy can not be removed from control-plane interface
Wizard4777
Coming across this error when trying to remove the policy. Is this system default?
Switch(config)#control-plane
Switch(config-cp)#no service-policy input system-cpp-policy
Switch(config-cp)#
*Mar 20 12:56:21.920: System cpp policy can not be removed from control-plane interface
Switch(config-cp)#
Cisco Catalyst C3850-48P Switch
control-plane interface <- this CPU
And this CoPP can not delete it can only modify
MHM
