Vpn between ir1821 and c921
bourbiayahia
I encountered an issue while trying to configure a LAN-to-LAN IPsec tunnel between an IR1821 and a C921 router.
I followed this guide: Cisco LAN-to-LAN IPsec Configuration.
The C921 is running version 15.9(3)M3, and the IR1821 is running version 17.13.01a.
Problem: I couldn’t ping between the two LANs.
Could this be a version mismatch issue or an incompatibility problem?
Share config of both Router let me check it
MHM
@bourbiayahia
 This guide you followed have troubleshooting section at the end and two command there are very important:
show crypto ipsec sa
show crypto isakmp sa
what do you see with this two commands?
