advice on trex
mulholland
folks
i'm looking at trex in cml and have managed to generate traffic by connecting the eth1 port onto the same lan as the device i'm testing but i want to push traffic through the device to an endpoint across the wan and so have some questions
- my trex node only show a single port, port 0, in the gui, is that expected
- does trex only work on the lan or can i generate traffic to test across the wan
- do i need to configure a gateway in trex to send traffic over a wan and if so how do i do that
- if can configure the trffic using the gui but can't seem to get into the cli of the trex node to add a route
thanks to anyone taking the time to respond, it's much appreciated
0 Replies 0
