Cisco Modeling Lab (Bios Error/Kernel Panic)
jonathan.loop
Good afternoon,
After loading the triangle sample lab on the CML UI I'm getting an interesting error when trying to activate the terminal straight out the box. Any ideas for what to do? I only have 6 cores so 4 i believe is the maximum i can dedicate.
according to https://developer.cisco.com/docs/modeling-labs/#!faq/installation-questions
server needs 16 GB of disk space per 1 instance, so it maybe populating space. Boot one at a time if you still have issues.
Regards, ML
**Please Rate All Helpful Responses **
Martin L
what is your PC specs? CPU, OS, VMware software, RAM ?
Double check your CPU is supported and Virtulization is enabled.
Has device booted properly? Yellow in CPU section is pretty close to "no go" If you are in Red, it is no go.  What happens after 10 minutes?
I would go to CLN CML group and ask  them
https://learningnetwork.cisco.com/s/topic/0TO3i00000094ZjGAI/cisco-modeling-labs-personal-community
Regards, ML
Host:
CPU: Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz, 3601 Mhz, 6 Core(s), 6 Logical Processors
OS: Microsoft Windows 10 Pro Education
VMware software: VMware Workstation
RAM: 32 GB
Virtualization: Enabled
Virtual Machine (Cisco Modeling Lab):
Memory: 19.5GB
Processors: 4
Hard Disk (SCSI): 60GB
Network Adapter: NAT
Configuration File: Cisco Modeling Lab.vmx
Hardware compatibility: Workstation 10.x virtual machine
Will test run for 10 minutes and let you know.
Regards, ML
