CML 1.1 and ASAv941 or ASAv952
Yasir Ashfaque
Hi Team,
I am a demo user of Cisco CML with cisco supplied CML box, I am running CML1.1 and most of the images i am running are running fine but only ASAv941, it seems like i cannot run it, tried multiple images same result.
in CML1.1 it shows ACTIVE, but in Console there is no response only cursor is blinking.
if i do vncview, i see it stucks here.(check attached)
any reason ? i have following images.
asav952.qcow2
asav941-200.qcow2
noabushe
It is normal that ASAv initially goes through 2 reboots. If you try and connect to it right away, you will see the experience youare talking about. Launch SImulkation and wait for about 5 minutes after it turns active and you should be able to telnet it.
