CML 1.1 unmanaged switch
nedludd
I am using CML version 1.1 and do not have the unmanaged switch node available. I have checked under File> Preferences> Node Subtypes and it is not listed there either. Does anyone know how I can add the unmanaged switch node to CML?
noabushe
The Unmanaged Switch node is an image that is part of the build and is listed under Nodes in the CML client. You do not have to do any extra steps to have it available in the palette.
Depending on the view of the node list, it might be pushed down the list (hidden) where you cannot see it. Try expand the list of the nodes view or reset the your CML client prospective ( tool bar-->window--> reset perspective).
Thanks for your response. I've checked the Nodes list and it doesn't show an icon for the unmanaged switch, I also don't have "windows" option in the toolbar. I've attached a couple of screenshots from CML which may throw some light on the issue.
