CML External Connection
rthomps43
Hello Everyone,
Is it possible to connect CML to another guest host running in the same VMWare host using the ext-con?  Currently, I have CML and a Windows Server 2019 running on VMWare Workstation Pro. I would like to figure out how to get connectivity between the two. My goal to is use the Windows Server to setup radius.
Thanks for your help.
shin.sterneck
Hi rthomps43,
when using the same virtual switch, this should be possible. Have a look at example:
Using Host-Only Virtual switch (no connectivity outside of the host)
https://docs.vmware.com/en/VMware-Workstation-Pro/16.0/com.vmware.ws.using.doc/GUID-E08995A9-7DE6-4D92-8C6F-4F737C3A8AB3.html
you can then associate the virtual switch within the ex-conn configuration (Edit Config --> Select Custom)
Shin
Martin L
Any Questions and/or issues should be asked at CLN CML subgroup forum;  find cisco learning network and cml forum
Regards, ML
**Please Rate All Helpful Responses **
