How to remove lab from CML 2 Dashboard?
vbassas
Imported the GARR sample lab into CML Personal and I want to delete it from the dashboard since the node count exceeds the personal license node number. The delete icon is in grey , even though all nodes are stopped. How can I remove it from the dashboard?
Martin L
Try delete it today.  You should be able to delete lab if it is stop and not in use.  If the node count exceeds your limit, then this lab will not start all its nodes but your other labs still should be fine.  So, it should not matter if this lab is "stuck" in there.
Regards, ML
**Please Rate All Helpful Responses **
Hi Martin,
I stopped every node and still I was unable to remove it from Dashboard.
What I did try and worked was the wipe icon. After stopping them , I wiped the lab and then I was able to remove it from dashboard. Is this the expected behavior?
Hi vbassas,
yes this is expected behavior. You need to wipe the config (or actually the state) to remove a node or a lab. It's documented here:
https://developer.cisco.com/docs/modeling-labs/#!deleting-nodes
Hope this helped!
regards,
Shin
a-gould
at 12:30 time in my video I explain this.
https://youtu.be/1td1FDL0-Iw?t=750
