Intervlan routing Cisco Modeling Labs (CML)
JJ8313
Hello, I am setting up an easy lab for inter-vlan routing using a router on a stick in CML.  pretty straight forward, right? not able to ping across sub-interfaces from the root switch. can ping 192.168.0.17 from switch, cannot ping 192.168.129 from switch.
!Configuration on the switch (Gi3/3 is connected to router on G0/1)
interface GigabitEthernet3/3
 description uplink
 switchport trunk allowed vlan 2-4091
 switchport trunk native vlan 8
 switchport mode trunk
 switchport nonegotiate
 negotiation auto
interface Vlan70
 ip address 192.168.0.18 255.255.255.240
ip default-gateway 192.168.0.17
!This is the router configuration
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
 media-type rj45
interface GigabitEthernet0/1.8
 encapsulation dot1Q 8 native
interface GigabitEthernet0/1.70
 encapsulation dot1Q 70
 ip address 192.168.0.17 255.255.255.240
interface GigabitEthernet0/1.177
 encapsulation dot1Q 177
 ip address 192.168.0.129 255.255.255.128
This should be easy, right?  all interfaces are up/up, I have an Linux workstation on at least one switch-port on the switch that can ping 192.168.0.129 on the router. however, cannot ping 192.168.0.129 from switch itself.  because I have the default-gateway set to 192.168.0.17 on the switch, the router should take over the routing to 192.168.0.129 subnet, but it fails.
balaji.bandi
If you had setup on switch VLAN and all the interface up and running.
check below information Switch ;
show ip interface brief
show interface status
show vlan (make sure vlan created ?)
change as below  on switch
ip routing  (both the side)
no ip default-gateway 192.168.0.17
ip route 0.0.0.0 0.0.0.0 192.168.0.17
BB
balaji.bandi
BB
yep, that solved it.  Interesting that CML doesnt support "ip default-gateway <address>" but have to configure: "ip routing" on the switch.  appreciate the help!
ip default-gateway used only when the device acting as Layer 2 only.
BB
yes, of course. That is what I had configured, a L2 Switch with a Router on a Stick to do the inter-vlan routing for the LAN.  But, as we have found out, that is not supported in CML because we had to make the L2 Switch a L3 switch.  Also, I made no changes on the router itself.  The only changes were on the L2 switch that is now a L3 Switch.  Thanks for the help.
