Lab Requirements for CISCO E-learning
I'm looking at taking Cisco's ENCOR E-learning. Does it Use CML? I don't have a computer that can run CML at this time and I would like to know if anyone here has taken/ran the course. Will I need my own computer or will lab environments be provided?
It should all be online, if not you can use the cml Devnet sandbox for free, so you won’t need to run anything big locally.
Good luck.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Jens Albrecht
Hello @frankbrasington97,
I assume that you talk about the ENCOR E-learning that is available at The Cisco Learning Network Store and also at Cisco U.
The lab environments for these courses are all hosted by Cisco.
When you click to start a lab, the environment will be prepared in the background which typically takes around 5 - 15 minutes depending on the amount of devices and complexity of the preparation scripts. During this preparation time you can continue to read through other sections or watch videos and you will get  notified once the lab environment is ready for you.
Access to the lab and and all devices like routers, switches, admin station, etc. is provided within the e-learning environment on your web browser. So the performance of your personal pc does not matter at all as long as you have a stable internet connection.
HTH!
Thank you very much for you help.
I was worried I would have to pay $1000 for the course AND buy a new PC.
