Need help with ospf lab
I was wondering if you could help me :
I was doing the lab 3-2 on this pdf : http://www.kis.fri.uniza.sk/~palo/Netacad/LST/ccnp-route-v6/en_ROUTE_SLM_v6000.pdf
I used this configuration the the three routers :
Router R1
hostname R1
interface Loopback1
description Engineering Department
ip address 10.1.1.1 255.255.255.0
ip ospf network point-to-point
interface Serial0/0/0
ip address 10.1.12.1 255.255.255.0
clock rate 64000
no shutdown
router ospf 1
network 10.1.1.0 0.0.0.255 area 0
network 10.1.12.0 0.0.0.255 area 0
end
Router R2
hostname R2
interface Loopback2
description Marketing Department
ip address 10.1.2.1 255.255.255.0
ip address 10.1.12.2 255.255.255.0
no shutdown
interface Serial0/0/1
ip address 10.1.23.2 255.255.255.0
clock rate 64000
no shutdown
router ospf 1
network 10.1.2.0 0.0.0.255 area 0
network 10.1.23.0 0.0.0.255 area 23
end
Router R3
hostname R3
All contents are Copyright © 1992–2010 Cisco Systems, Inc. All rights reserved. This document is Cisco Public Information.
Page 17 of 18CCNPv6 ROUTE
interface Loopback3
description Accounting Department
ip address 10.1.3.1 255.255.255.0
interface Loopback20
description Connection to another AS
ip address 172.20.200.1 255.255.255.0
ip address 10.1.23.3 255.255.255.0
no shutdown
router ospf 1
redistribute connected subnets
network 10.1.3.0 0.0.0.255 area 23
end
However unlike on the lab when I do a : show ip ospf neighbors
I get 172.20.200.1 as neighbor and not 10.1.3.1 as it mentions on the lab on page 155 ( same lab ). Can someone help explain? I am not advertising that network (172....) why is it showing up as neighbor?
I am using 3500 router image on GNS3.
thanks
Vince
It may have something to do with the router-id selection process. The router will choose the highest IP of the loopback, or highest IP of physical interface (if loopback is not present) to be it's router-id. It doesn't matter if it is advertised or not.
If you want to use 10.1.3.1, you can use router-id 10.1.3.1
Vince
