packet capture CML-P export to wireshark
jason123
is there a way to export the packet capture which is run within the web gui of CML-P to wireshark so i can see more detail about the packets that are captured ?
You could use span on a switch port, and the install wire shark on a alpine Linux node, just a thought.
I have not played or discovered the cml in built one
