Personal Cisco Modeling Labs 2.1 - I can not access device console
aalshaya1
I've installed CML on VMWare Fusion, it is working fine, but when I try to connect to console of any node of my lab I am unable. The following message appear : Press 'enter' to activate this terminal. I press enter and nothing happen.
Screen Shot 2020-11-18 at 1.43.27 PM.pngScreen Shot 2020-11-18 at 1.46.22 PM.pngScreen Shot 2020-11-18 at 1.51.24 PM.png
Martin L
I have  not updated my CML to 2.1 yet, so not sure but I see on 1st picture under Nodes shows devices as "Queued" and not started; Double check if devices are running; and try again.
Also check CML group on learningnetwork.cisco.com
Regards, ML
**Please Rate All Helpful Responses **
Neville_Sears
Hey aalshaya1 ,
I had this issue myself, the fix for me was to go into the cml-controller.cml.lab and and run the clean up. It does not wipe any of your labs etc, but it's a good ide to back them up prior.
Hope this helps.
