problem to configure cisco Router 887va k9
Dossos001
Hello everyone
please if someone can help me .
I buy cisco router 887va k9 he is layer 2 router. it is my first time to see that , someone told me because I have a basic ios .
but if buy a new licence the router can work on layer 3 . And I buy advanced IP services License but it doesn't work on layer 3
please can you help me
My best regard
Dosso
12 Replies 12
Mark Malone
an 887 is a layer 2 switch and a layer 3 router , it should have come with an ipbase license
If you want advanced routing features like pbr/sla/bgp etc you will need to buy the license
You can still do static routing and maybe eigrp stub routing basic opsf but not full protocol features  on base license
so all you have to do is buy the license or use it for the layer features it currently has
But be assured its layer 3 and 2
Hi Mark
thank for your answer .
I bought a new license  It is ( advanced IP services License) but it is still on layer 2
what can i do to get the layer 3 feature . which license i must to buy ?
My best regard
Dosso
Hi did you apply ? it can you post show license  please
if is applied right you should have eigrp go to like
see if it takes the below
conf t
router eigrp 100
hi Mark
here is my show license
Router#show license
Index 1 Feature: advipservices
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 2 Feature: advsecurity
License State: Active, Not in Use
Index 3 Feature: ios-ips-update
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Not in Use, EULA not accepted
License Priority: None
Index 4 Feature: MEM-8XX-512U1GB
that's applied correctly you should now have full layer 3 routing , why do you think its only layer 2?
can you go into conf t mode and check what protocols you can use now with below
conf t
router ?
You should see bgp,ospf,eigrp etc and you should now be able to use them
Test by configuring  protocol it should now take the below as an example
router bgp 65000
ohh sorry May be you don't understand me. when I said it is on layer 2 because I can't assign the IP address on interface . of course it is doing a routing My best regards
Ah ok that's different definitely misunderstood :) the module inside a 800 series is purely layer 2 so you cant assign an ip address to it at all by design, only the wan interface is capable of ip address F4  , the switch module is capable of trunking only but you can create a vlan interface with an ip address and then assign the ports to that vlan or create the vlan and assign the switchports to trunk mode and connect up a switch to give you much more ports
interface vlan 1
ip address 10.1.1.1 255.255.255.0
Then
interface f0
switchport access vlan 1
ot
interface f1
switchport mode trunk
first of all you thanks to give to me your time to answer my question .
I want to know something even I buy new license the interface will not work on layer 3?
My best regards
Dosso
No the license is to allow you do full routing layer 3 and all the features like policy based routing and ip sla etc , with the out of the box license you can only do basic layer 3
The switch module inbuilt in an 800 series does not allow ip addressing at all pure layer 2 switchport its not programmed to be able to do layer 3 all , this goes for every model 800 series , 887 ,881 867 etc
thanks a lot
if I assign vlan for each port how can I configure Ip helper with Microsoft server 2012 R2?
if you  can help me for that one , it will resolve all my problem
My best regards
Dosso
Yes no probs
all you do is the  below and you can have multiple servers as well one under each other if required , its not round robin though first server to respond with usable address is used
Interface vlan x
ip helper-address 198.3.12.4
interface vlan123
  desc svi for vl123 dhcp relay example
  ip address 192.0.2.1
  ip helper-address 192.0.4.1 ! Primary DHCP server
  ip helper-address 192.0.4.2 ! Secondary DHCP server
good morning
My problem is that , I have a server 2012 r2 we have 3 department . My Boss want each department to get is  own network. so I created 3 DHCP scope with different subnet . EX: 172.16.7.0/24  192.168.1.0 /24 10.0.0.0 /24
vlan 1 with 172.16.x.x assign to port F1
Vlan 12 with 192.168.x.x assign to port F2
vlan 15 with 10.x.x.x assign to port F3
how can i configure Ip helper , then each department can get the different ip addr
if you can help me for that ?
My best regards
Dosso
