Risk or Need to Bridge CML to production network? - Prefer Isolated Sandbox
michaelc0n
My question is when I deploy CML within my production network, on a production ESXi host how much risk is there when spinning up lab networks within CML to bridge into my production network via the ESXi host?  I of course want to be able to take full utilization from a CML client/server perspective but I don't want to introduce any unnecessary risk to my underlining production network where the ESXi host will be residing...
Please let me know the best way to deploy CML on ESXi to avoid bridging to "underlay" production(real) network into the simulations provided atop of CML...
Thanks!
5 Replies 5
rkochery
Hi Micheal,
 Unless External Connectivity is not configured on the CML Server, it will not communicate with outside world. its absolutely safe.
Romal
Thank you for your feedback! How can I ensure I do not enable external connectivity? Is there a config. guide that references external connectivity
you have all the installation instructions in
http://virl-dev-innovate.cisco.com/client.php
you should leave all the ip address to default values.
Romal
Hi Romal,  appreciate the help and the link! The below is a snippet from the link you provided...my question is if I don't want to bridge the CMLenvironment (I  don't have VIRL, probably easier to install) into my real L2 or L3 network do I still need all those port-groups?  I would prefer to just have a single IP tied to CML-server which by my CML-client connects to and just have a sandbox to do testing within CML. What are your thoughts on this?  Thanks again for all the help.
Step 3:  Create the VIRL Network Port-Groups
The VIRL virtual machine requires connections to five unique virtual network port-groups, the first of which ('VM Network' by default) is used for management and connectivity to the Internet.
The other four port-groups used by VIRL for external layer-2 and layer-3 connectivity ('Flat', 'Flat1', 'SNAT', and 'INT') must be created using the steps below:
Hi Micheal,
 All the simulations running in the CML Stays inside the CML. it does not communicate with anything outside the Virtualized CML Server. Even though you create the port groups, the ip addresses assigned to them by default are private ip addresses and they are not routable.
In the settings.ini file you can leave all the port group ip addresses to default values.
