Simulate OTV FHRP isolation in Cisco Modeling Lab
DRS60606
I simulated our production VXLAN/OTV configuration within CML v1.5.148.
The fabric and 'core' switches are all running NX-OSv 9000 images. Since the NX-OSv 9000 images don't support VDCs, I simulated OTV using a pair of CSR1000v nodes.  Traffic across the OTV is working as it should.
There are stretched vlans going across OTV. The problem I'm running into is getting FHRP isolation working. I need to build a "mac-list" filter but it doesn't seem to be a supported command on the CSR1000v.  Anyone get FHRP isolation working? If so, which node type did you use?
0 Replies 0
