Trex Connection failing between CMLand Trex stateless GUI (v2.61)
mohanprasad
Steps followed to Install Trex:
  • Connect TREX eth0 interface to external connector.
    1. Set External Connector in bridge config mode
    2. Eth0 port is mgmt.
  • Connect TREX eth1 interface to another router/switch,
    1. In eth1 we want to send traffic
  • Give the below config in TREX for assigning static IP:
# this is a shell script which will be sourced at boot
hostname inserthostname-here
# configurable user account
USERNAME=xxx
PASSWORD=xxx
hostname trex-0
ip addr add dev eth0 172.18.29.123/24
ip link set dev eth0 up
The console would be like this after bringing up the lab:
  • In CML available TREX version – 3.16.2:
  • Download the TREX stateless GUI from
https://github.com/cisco-system-traffic-generator/trex-stateless-gui
Used the version v4.5.6.exe package which support of TRex v2.61.
  • Installed it and able to open the GUI
  • But not able to connect to TREX IP
Possible issues:
  • Firewall blocking the IP
  • Configuration (port number) in TREX might be issue.
  • CML Trex version and exe file version might not be compatible.
kipandiy
Hi @mohanprasad The instruction setup looks good. The Trex 3.16.2 image will work well with Trex GUI v4.5.6. Guess it could be firewall blocking your configured IP.
rkochery
Hi @mohanprasad , Does external connectivity using bridge work for other node types? You could try connecting the ext-conn to a linux node and assign a static ip to it. Verify that external connectivity using bridge is working fine. Also refer external connectivity troubleshooting steps in CML troubleshooting FAQ item #7 or #8 depending on your deployment type.  https://developer.cisco.com/docs/modeling-labs/#!faq/troubleshooting
