Inter-Vlan routing using Multi layer switch
marvashahid09
I have done all the correct things but I am unable to do inter vlan routing. The PCs in the Vlans show DHCP request failed, APIPA is being used. I have used static routing and ip-helper address commands. The required vlans are also up on the multi layer switch. I have my project submission but I am unable to figure out the problem. I have spent more than 6 hours searching about this but in vain.
5 Replies 5
M02@rt37
Hello @marvashahid09
Please share your project here in a zip files.
Best regards
marvashahid09
Also, I am supposed to implement NAT on the router in Network G, so does it mean that I will have to implement the NAT on all the routers , because any router connected to that router will also require NAT to be implemented
@marvashahid09
in the project you shared, there is no configuration on Router21....
Best regards
I did configure it, I don't know why it shows up there like this. But DHCP server for VLAN should still work nonetheless
