Reload Command to Reboot Both Active and Stby Switch on Modular C9606R
bong31
We are planning to do failover test on our redundant core switches by shutting down 1-pair(active and standby) of core switch and the other pair should take over. Appreciate anyone can share on the step and command/s on how to reboot both the active and standby switch?
#show switch
Switch/Stack Mac Address : <MAC ADDRESS> - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
1 Standby <MAC> 1 V02 Ready
*2 Active <MAC> 1 V02 Ready
#show redundancy
Redundant System Information :
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = sso
Operating Redundancy Mode = sso
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = Switch 2
Current Software state = ACTIVE
Image Version = Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.3.4,
Peer Processor Information :
Standby Location = Switch 1
Current Software state = STANDBY HOT
Hello @bong31 ,
to reload the entire stack, just issue the reload command:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9600/software/release/17-6/command_reference/b_176_9600_cr/high_availability_commands.html#wp1755162844
Regards, LG
*** Please Rate All Helpful Responses ***
Have confirmed with TAC and reload is the command. Alternative is 'redundancy reload shelf' which will also reload both stacked switch as tested in lab. Thank you.
Leo Laohoo
reload
