Setting up site-to-site VPN with Cisco ASA firewalls - Need help!
jasonroy1565
Hello Cisco Community,
I'm currently facing some challenges in configuring a site-to-site VPN between two Cisco ASA firewalls, and I'm seeking guidance and expertise from the community.
Description:
I have two Cisco ASA firewalls (ASA 5500-X Series) and I need to establish a secure site-to-site VPN connection between them. The purpose is to securely connect two separate networks located in different physical locations. I've attempted to configure the VPN tunnel following the Cisco documentation, but I'm encountering issues and the VPN connection is not establishing successfully.
Here are some specific areas where I need assistance:
Initial configuration: What are the essential configuration settings required on both ASA firewalls to enable the site-to-site VPN functionality?
VPN parameters: How do I correctly define the encryption algorithms, authentication methods, and Diffie-Hellman group for the VPN tunnel?
Access control: How can I configure the necessary access control rules and firewall policies to permit traffic between the two networks?
Troubleshooting: What are the recommended troubleshooting steps and commands to identify and resolve any potential connectivity or configuration issues?
I have reviewed the Cisco documentation, but I'm still facing difficulties in getting the VPN connection up and running. I would greatly appreciate any guidance, step-by-step instructions, or sample configuration examples that can help me successfully configure the site-to-site VPN using Cisco ASA firewalls.
Thank you in advance for your valuable assistance!
Blue_Bird
Step 1:- Create Crypto Ikev1 Policy
In this step, we will configure the HAGLE information.
Hash, authentication, group, encryption must be the same on both sides.
ASA1(config)# crypto ikev1 policy 10
ASA1(config-ikev1-policy)# hash sha
ASA1(config-ikev1-policy)# authentication pre-share
ASA1(config-ikev1-policy)# group 2
ASA1(config-ikev1-policy)# lifetime 86400
ASA1(config-ikev1-policy)# encryption 3des
Step 2:- Create A Tunnel-Group To Specify A Pre-Shared Key For Peer
The pre-shared key should be the same on both sides
To create a tunnel group, there are two steps :
Create tunnel-group
ASA1(config)# tunnel-group 102.1.1.10 type IPsec-l2l
Specify pre-shared key in tunnel-group
ASA1(config)# tunnel-group 102.1.1.10 IPsec-attributes
ASA1(config-tunnel-ipsec)# ikev1 pre-shared-key cisco
Step 3:- Create IPsec Transform-Set
ASA1(config)# crypto ipsec ikev1 transform-set TSET esp-3des esp-sha-hmac
Step 4:- Define Interesting Traffic ACCESS-LIST
Traffic which we want to secure via VPN that is Interesting traffic (192.168.1.1 and 192.168.2.1)
ASA1(config)# access-list VPN-ACL permit Ip host 192.168.1.1 host 192.168.2.1
Step 5:- Create A Crypto Map
It is used to create a particular list of VPN ACCESS-LIST, TRANSFORM-SET, and PEER IP.
ASA1(config)# crypto map CMAP 10 set peer 102.1.1.10
ASA1(config)# crypto map CMAP 10 set ikev1 transform-set TSET
ASA1(config)# crypto map CMAP 10 match address VPN-ACL
Step 6:- Enable IKEV1 And Apply Crypto Map On The Interface
ASA1(config)# crypto map CMAP interface outside
ASA1(config)# crypto ikev1 enable outside
Step 7:- Apply Same Steps For Branch 2 ASA Device
Ip addresses may not same as your requirement...you can change or replace it correct one's
Best regards
******* If This Helps, Please Rate *******
