Does Proximity work with SX10n
Gopilan110
I would like to know if proximity works with SX10n please?
I have tried all the options mentioned in the forum but none of them work for me.
Gobi
Henrik Bakken
Yes - the SX10N is definitely supported.
Can you verify you have enabled Proximity (xCon Proximity Mode: On, and enabled all the services)? And that you run CE 8.x?
Have you verified any ultrasound token sent from the unit?
There is a thorough trouble shooting guide here: https://supportforums.cisco.com/document/12159326/troubleshooting-guide-cisco-proximity
Try specifically the part listed in "Ultrasound Analysis" if you are stuck.
Hope this helps,
-Henrik
Wayne DeNardi
Yes, the SX10n was specifically designed to work better with proximity than the "SX10 (no N)" version it replaced.
This is discussed in the Product End-of-Life Notice for the SX10: http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/telepresence-quick-set-series/eos-eol-notice-c51-736393.html
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
