Proximity & Wi-Fi connection
Hello !
I would like to know if, during using proximity, I can stay connected to our infrastructure via Wi-Fi to reach server ressources ?
Thank you and best regards.
Yes.  It is a requirement for proximity that it has access to your corporate network and can access the endpoint via http to communicate with it, so if you are able to access the endpoint normally via your network as well as your files you will still be able to while using proximity to do the screen sharing.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
