Cisco Meraki - Device adding issues
martinsebo
Hello, I'm writing you because I'm trying to add a couple of devices to Cisco Meraki (only tried MV2 cameras so far).
I've tried to add them to our company network via a mobile app Meraki using both scanner and manually typing in serial numbers of both cameras. In the case of trying to add one using the scanner, it's got me only as far as adding the camera to the device inventory but when I try to add the said camera through the Add device screen, after pressing Done I get an error dialogue window saying: Please return to add new device and re-add serial.
When I try to add the second camera using the Add device by serial number method instead, I get another error message: Invalid response.
I'm adamant the serial numbers are correct, especially the one I scanned, otherwise it wouldn't show in the Device inventory showing the right device model name.
Thank you.
//EDIT: I've managed to solve all the issues. You can close this thread. Thanks.
helpcenterus
Can you describe how you solved this problem?
