Restart switch when enable logging facility
hunterman
Hello everyone,
When i enable the command logging facility  and after enabled so the switch automatic go to restart after reboot and opened the ssh on the quickly to disable or remove the command, Below all command and ("192.168.1.25" my syslog server and Switch model 2960x and version 15.0(2a)EX5):
logging facility news
logging host 192.168.1.25
login on-failure log
login on-success log
logging trap informational
Any one can help to solve the problem?
THANKS
Thank you for your replay,
If you can advice me whats the benefit to "logging facility news", After that I tried to upgrade the version from  version 15.0(2a)EX5 to last upgrade Version 15.2(6r)E , After that i tested the all same command in below
And the switch worked without any problem, In this time if i apply your command below
logging buffered 64000 <-- change the value as per your requirement
After that the switch worked without any problem where the version 15.0(2a)EX5 ? Or i forced to all switches upgrade to last Version 15.2(6r)E .
6 Replies 6
balaji.bandi
no logging facility news   <-- i do not belive you need this
Save config test and advise.
You still have issue, post show logging
BB
logging facility news   ( do you really need this usenet ?)
News USENET news
if the solution is resolved can you mark as resolve so it will be usefull for other community members,.
BB
If you can explain me whats the benefit to "logging facility news" ? or logging facility USENET news ?
High level :
NEws - Log Messages regarding USENET  news processes
If you like to more about technology, would nice to spend some time on RFC
https://tools.ietf.org/html/rfc5424
https://en.wikipedia.org/wiki/Usenet
BB
I'm solved the problem when upgrade the switch version from 15.0(2a)EX5 to Version 15.2(6r)E .
If any one have the same problem please upgrade because the version 15.0(2a)EX5 have bug in software version .
THANKS
