2.1.1.5 Packet Tracer - Create a Simple Network Using Packet Tracer
xerez1947
Hi!
First at all, I am not sure if this location is the best for my question, so sorry if it is not here.
I am doing the course "Introduction to Packet Tracer" in NetAcad and I need help.
I am traying to complete the point "2.1.1.5 Packet Tracer - Create a Simple Network Using Packet Tracer.pdf".
However I am not able to pass this part:
b. Identify the From and To Ports
Click on the Config tab in the Cloud device window. In the left pane click on Cable under CONNECTIONS. In the first drop down box choose Coaxial and in the second drop down box choose Ethernet then click the Add button to add these as the From Port and To Port as shown in the figure.
When I go to Cable in Config tab I can see Coaxial7 to be selected as From Port, but in the second box I don't see anything.
What is wrong? How can I get Ethernet interface in the second box?
Thanks!
35 Replies 35
Thanks again!
Frontier Pte Ltd is a small consultancy company. The company has decided to move to a new site. You are a network engineer and are engaged to set up a network for his company.
The company has 3 departments (Engineering, Finance and Human Resource) in a building. The number of staff and the allocated IP address range is shown as follows:
Department
Location
IP address Range
Default GW
Assigned Vlan
Engineering
Levels 1,2,3
192.168. 201.0/24
192.168.201.1
201
Finance
Levels 1,2,3
192.168. 202.0/24
192.168.202.1
202
Human Resource
Levels 1,2,3
192.168. 203.0/24
192.168. 203.1
203
Additional information for the servers is below
Server
Location
IP address
Default GW
Assigned Vlan
DHCP Server
Datacenter
192.168.2.11/24
192.168.2.1
AAA Server
Datacenter
192.168.2.12/24
192.168.2.1
Architecture Requirements
3 Tier architecture applied and labelled correctly - We will be using a collapsed core design
Connections between devices should use the highest speed possible. This includes selection of cables.
All devices hostname and labels to unique and be set/named accordingly.
Each PC should be connected to a switch residing on the same floor.
L2 Features
VLANs to be configured on the core switches
VLAN information should never be configured on the access switches.
VLAN information propagation to the other switches should be secured.
All inter-switch ports should be set unconditionally to trunk mode.
L3 Features
Each L3 switch/router SVI should be configured correctly with the correct IP address
Devices on each VLAN should be obtain their address from the single DHCP server.
Security Features
All trunk links to utilize a non-default native VLAN.
Users are to be authenticated before access to the network is allowed.
Port security is to be implemented for all edge ports. Each port to allow the first 2 devices connected to the port, with the addresses saved into switch running memory.  Connection of unauthorized PCs should not stop authorized PCs from working on the port.  Notification is to be sent by the switch to the logging server if this happens.
All edge ports are to guard against rogue DHCP servers
All access ports to have dynamic trunking protocol disabled.
6
All unused ports are to be disabled.
Switch Management
All switches are to implement out of band login (id/password on attachment below)
All switches to have only appropriate secure in-band remote management login.  (id/password as attachment below)
Each switch to have an IP address separate from any user facing VLAN.
Misc
Configure the DHCP server with the required scope for the 3 user VLANs.
2.
Configure the AAA server with the usernames and the passwords, and also add the authenticator’s IP address inside for radius authentication.
The user passwords for local authentication to the network are as follows
AAA Server userid / password
S/N
Userid
Password
01
fin01
12345
02
fin02
12345
03
fin03
12345
04
eng01
12345
05
eng02
12345
06
eng03
12345
07
hr01
12345
08
hr02
12345
09
hr03
12345
The management passwords for device local and remote management are as follows
Out of band switch userid / password.
S/N
Userid
Password
01
localuser
12345
In band switch userid / password.
S/N
Userid
Password
01
remoteuser01
12345
02
remoteuser02
12345
Available Physical Resources
The Assignment.pkt file contains all the devices with services required. You are to connect them using any cable and configure them.
All the servers are configured with user ids / DHCP scopes. You can add missing configuration but you cannot change or delete any existing configuration.
You are to work with only the existing equipment.  (it should not be necessary to utilize all devices)
You are NOT to add/remove any devices.
Introduce Network Topology (mandatory)
(1) Each PC should be connected to a switch residing on the same floor.
(2) VLAN information propagation to the other switches should be secured.
(3) All switches are to implement out of band login.
(4) All unused ports are to be disabled.
(5) Configure the DHCP server with the required scope for the 3 user VLANs.
Good Day,
I am finding the same issue and unable to perform the final test of resolving "Cisco.com" from PC, and get this message on pinging "Ping request could not find host cisco.com. Please check the name and try again."
Please help me to find out what i am missing, I have uploaded the pkt file.
Thanks in advance.
Check the DNS configured on the Wireless Router.
I think you typed 208.57.220.220 instead of 208.67.220.220
Good Day Cesar_,
Thanks for your help on this and as this was driving me nuts. I have no clue about networking concepts and was not sure how I will get any help. People like you play a great role to building confidence.
Hi @DEEPAKCHETTY9733 ,
Follow these steps to solve the problem:
Enter the router
Correct the second octet of the DNS address, it must be 67
Save the changes
Enter the PCs and go to Desktop> IP Configuration
Renew the DHCP request, choosing Static and back to DHCP
After those changes, everything will be ok
The DNS address on the PCs must be 208.67.220.220
Good Day luis_cordova,
Thanks for taking so much of pains to put a screenshot and your help on this greatly appreciated. This gives me confidence that I am in the right place to learn and grow with support from people like yourselves.
I'm glad to help you. I encourage you to continue with your desire to learn and your curiosity.
Remember to mark the correct answers as a solution, because that helps other users with similar questions.
Thankyou Luis,
I know this is an old thread but it remided me that its the simple things that trip us up and have us scratching our heads,
Like the save button at the bottom of the wireless router page ...!!
All working now, saved and onto the next task.
Thanks again...
I'm also facing this same issue. Who to rectify it .please help me.
ourmaninboston
I had the same issue, then seeing I could reach the default gateway, I knew it was something past that point. After that, I carefully combed through the instructions again. I'd missed one small step: clicking the "Add" button to add the cable to the ports on the internet cloud. As below:
As soon as I did that, everything worked fine. ;-)
Lin1
I'm having the same issue, not being able to ping Cisco.com. I have attached my .pkt file below. Help would be appreciated.
Hi @Lin1
You just have to change the cable to a crossed one.
After that change, the problem is solved.
Thanks for the help, that solved the issue.
Hi @Lin1
Excellent, remember to mark the answers as solved, because that helps other users.
