assignment pls help :(
jumbopro2511
Community Member
ive been trying to do this part for 2 weeks already pls someone help me, from INSIDE PC i want to access the web server in dmz.
@jumbopro2511 hi, it looks like your routers dont have proper routing information. do you have guide for this lab? or is it built by you?
1. your routers need to know about the networks connected each other as well as other networks. for ex. router at left side need to know how to get in to DMZ network.
2. if you planning to use dynamic routing protocol, make sure to add correct network commands in configurations.
Good luck
KB
hi i built it my self, the routing network configuration do u mean this "network 209.165.200.225 0.0.0.0 area 0"?, thanks for your guidance.
