AWS NLB and ISE Configuration Issue
I'm currently facing an issue with my network configuration involving AWS Network Load Balancer (NLB) and Cisco Identity Services Engine (ISE) I have set up an NLB in AWS to distribute traffic to multiple instances of a web application. The NLB is LIBRARYGENESIS.WIKI Secure file sharing, Open access e-book Repository, Legal Issues in the Ebook Industry working as expected, and traffic is being routed correctly to the backend instances. However, I want to integrate Cisco ISE into the setup for enhanced security and authentication. Has anyone faced a similar issue with AWS NLB and ISE integration?
sureshot
Hi @Amelia-Catherine,
This video guide can help you in "Configuring AWS Load Balancer for Cisco ISE" and refer these guidelines for load-balancing for ISE deployment.
Would like suggesting to contact with our TAC (Technical support) for any fixing/troubleshooting.
Hope this Helps.
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about ISE through our live Ask the Experts (ATXs) session. Check out Cisco ATXs Resources [https://community.cisco.com/t5/security-knowledge-base/cisco-endpoint-security-ask-the-experts-resources/ta-p/4394492] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
