08-12-2019 07:26 AM
Hi everyone,
I have couple of Cisco Nexus C3548P-10GX config running VPC with it.
I have an issue that: the couple of switch randomly reboot unexpectedly with the reason i saw the the `show system reset-reason` command is that:
My switch system information below:
I search for bug on cisco page, but no report about this issue with NXOS 9.2(2).
Anyone have met this issue? And is there any solution or patch fix for this bug?
Thanks So much!
10-21-2020 06:16 AM
We have a customer with the same thing happening on a 3064PQ-10GX ,device is running on almost the most recent NX-OS version : 9.3.4.
Software
BIOS: version 5.0.0
NXOS: version 9.3(4)
BIOS compile time: 06/05/2018
NXOS image file is: bootflash:///nxos.9.3.4.bin
NXOS compile time: 4/28/2020 21:00:00 [04/29/2020 06:28:31]
Hardware
cisco Nexus3000 C3064PQ Chassis
Intel(R) Celeron(R) CPU P4505 @ 1.87GHz with 3901824 kB of memory.
Processor Board ID FOC1723XXXX
Device name: nxs-core2
bootflash: 1638000 kB
usb1: 0 kB (expansion flash)
Kernel uptime is 0 day(s), 0 hour(s), 42 minute(s), 46 second(s)
Last reset at 92148 usecs after Wed Oct 21 05:56:10 2020
Reason: Reset Requested due to Fatal System Error
System version: 9.3(4)
Service: sysmgr failed to re-register with heartbeat klm
plugin
Core Plugin, Ethernet Plugin
Active Package(s):
10-21-2020 06:17 AM
Did you solve this ? If yes what did you change/perform ?
10-21-2020 06:24 AM
It seems to be the same situation as this bug with the 5.0 release NX-OS : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCup90920/?rfs=iqvred
09-13-2023 03:15 AM
Facing same issue in the cisco Nexus3500 C3548P-10GX Chassis , Please find below details and version
Software
BIOS: version 4.2.0
NXOS: version 9.2(2)
BIOS compile time: 09/23/2017
NXOS image file is: bootflash:///nxos.9.2.2.bin
NXOS compile time: 11/4/2018 21:00:00 [11/05/2018 06:11:06]
Hardware
Intel(R) Core(TM) i3-3227U CPU @ 2.50GHz with 16397264 kB of memory.
Processor Board ID FOC26347DR8
Device name: AT10-10G-248
bootflash: 15141888 kB
usb2: 0 kB (expansion flash)
Kernel uptime is 0 day(s), 5 hour(s), 18 minute(s), 4 second(s)
Last reset at 452626 usecs after Wed Sep 13 03:59:25 2023
Reason: Reset Requested due to Fatal Module Error
System version: 9.2(2)
Service: System manager
plugin
Active Package(s):
AT10-10G-248# show system reset-reason
----- reset reason for module 1 (from Supervisor in slot 1) ---
1) At 452626 usecs after Wed Sep 13 03:59:25 2023
Version: 9.2(2)
2) At 910892 usecs after Fri Jun 9 08:59:24 2023
Version: 9.2(2)
3) At 854393 usecs after Sun Feb 12 17:59:36 2023
Version: 9.2(2)
4) At 835457 usecs after Sun Nov 27 13:59:49 2022
Version: 9.2(2)
AT10-10G-248# show cores
VDC Module Instance Process-name PID Date(Year-Month-Day Time)
1 1 1 aclqos 29208 2023-09-13 04:02:12
AT10-10G-248# show logging onboard internal reset-reason
Module: 1
Last log in OBFL was written at time Wed Sep 13 10:03:46 2023
Reset Reason for this card:
Image Version : 9.2(2)
Reset Reason (LCM): Unknown (0) at time Wed Sep 13 04:03:15 2023
Reset Reason (SW): Reset Requested due to Fatal Module Error (4) at time Wed Sep 13 03:59:25 2023
Service (Additional Info): System manager
Reset Reason (HW): Unknown reason (0) at time Wed Sep 13 04:03:15 2023
Is there any solution or patch fix for this bug?
