Cisco 2960-24-PCL Web Browser appearance problem
tomnick
Hello everybody,
I bought 2 used 2960-24-PCL and configured them from scratch using the software 12.2(55)SE12. Everything works fine so far, I can login via web interface and it looks perfect. But: I can click any link on that site and it wont open except the "legend" window. I tried Brave, Edge, Firefox, different PC,  all the same. Does anybody have any idea what I might have done wrong? Thanks for some help.
Use a Windows 7 machine with Internet Explorer browser.
6 Replies 6
Leo Laohoo
Is there any CLI access?
yes, there is via serial
Post the complete output to the following commands:
  1. sh version
  2. dir
  1. sh version
  2. dir
2 drwx 512 Mar 1 1993 00:31:38 +00:00 c2960-lanbasek9-mz.122-55.SE12
558 -rwx 1919 Mar 1 1993 00:02:11 +00:00 private-config.text
559 -rwx 3096 Mar 1 1993 00:02:11 +00:00 multiple-fs
560 -rwx 108 Mar 1 1993 00:38:51 +00:00 info
561 -rwx 1915 Mar 1 1993 00:02:22 +00:00 private-config.text.renamed
562 -rwx 1653 Mar 1 1993 00:02:10 +00:00 config.text
Directory of flash:/c2960-lanbasek9-mz.122-55.SE12/
3 -rwx 539 Mar 1 1993 00:31:38 +00:00 info
4 -rwx 9827106 Mar 1 1993 00:31:39 +00:00 c2960-lanbasek9-mz.122-55.SE12.bin
5 drwx 5632 Mar 1 1993 00:35:11 +00:00 html
Switch1#sh version
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(55)SE12, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 28-Sep-17 02:53 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01900000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(53r)SEY3, RELEASE SOFTWARE (fc1)
Switch1 uptime is 16 minutes
System image file is "flash:/c2960-lanbasek9-mz.122-55.SE12/c2960-lanbasek9-mz.122-55.SE12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960-24PC-L (PowerPC405) processor (revision M0) with 65536K bytes of memory.
Processor board ID FCQ1732Y14N
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 50:17:FF:A3:61:00
Motherboard assembly number : 73-12619-05
Power supply part number : 341-0266-03
Motherboard serial number : FCQ17310PW3
Power supply serial number : LIT17250LVY
Model revision number : M0
Motherboard revision number : A0
Model number : WS-C2960-24PC-L
System serial number : FCQ1732Y14N
Top Assembly Part Number : 800-32808-02
Top Assembly Revision Number : A0
Version ID : V07
CLEI Code Number : COMCS00ARD
Hardware Board Revision Number : 0x02
Switch Ports Model SW Version SW Image
* 1 26 WS-C2960-24PC-L 12.2(55)SE12 C2960-LANBASEK9-M
Configuration register is 0xF
Uhhhhh, nightmare, you thing it wont work with "todays" system?
