CLI Command to view process running on a port
I am unable to establish a connection with the oracle database of Ise . Is there any command on cli to check which processes are running on which ports, so that i can be sure , that the details I am entering are correct .
@jagritibhardwaj471
 On this guide, scroll down to the bottom and there will be a few commands for troubleshooting
https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine/211581-Configure-ODBC-on-ISE-2-3-with-Oracle-Da.html
Hey,
I am unable to see any commands for this . Also , if u could provide commands for CLI for ISE 3.3 to see which service/process is running on which port .
Basically , I want to check , after enabling the dataconnect feature the oracle db is running on which port , and what is the host IP. Because i am unable to connect to the oracle db , the error i am encountering is ,
                                  ORA-12541: Cannot connect. No listener at host <ip of Ise server> port 2484.
You will want to verify that you have enabled the ISE Data Connect feature which requires ISE 3.2 or later. You may watch our webinars which show how to enable and use Data Connect:
▷ Next Generation ISE Telemetry, Monitoring, and Custom Reporting Part 2 |
06:00 Reports vs Data Connect
08:10 Data Connect (ISE 3.2 and later)
How to Get Data Out of ISE | 2024-04-02
48:32 ISE Data Connect
You may view all ISE services from the command line with show application status ise
Consult the ISE 3.3 CLI Guide (https://cs.co/ise-berg#3.3) for all available commands and usage.
I recommend posting Cisco Identity Services Engine (ISE), RADIUS, and TACACS+ related questions in the ISE/NAC Network Access Control (https://cs.co/ise-community) community forum for the best visibility and RADIUS expertise.
