CML 2.6.1 NXOS Issue with Intervlan Routing
Raid3n
Good day,
I am using CML 2.6.1, have a simple topology built, with two hosts, and a single Nexus 9K device. Both hosts are connected to the device. The configurations are default, except the following:
- There are 2 vlans on the nexus, vlan 2 and vlan 3
- Host 1 is in vlan 2, Host 2 is in vlan 3
-Nexus feature for intervlan routing is enabled
-Nexus interfaces for vlan 2, and 3 both exist, as well as the vlans themselves.
Vlan 2- 192.168.2.254/24
Vlan 3 - 192.168.3.254/24
Host 1 - 192.168.2.1/24
Host 2 - 192.168.3.1/24
Host 1 and host 2 can both ping the vlan interface for their vlans on the nexus (.254), but cannot ping each other. Routes exist in the routing table as expected.
Interface configs:
interface Ethernet1/1
switchport access vlan 3
interface Ethernet1/2
switchport access vlan 2
interface Vlan2
no shutdown
ip address 192.168.2.254/24
interface Vlan3
no shutdown
ip address 192.168.3.254/24
Feature:
interface-vlan 1 enabled
This seems like a bug. I've tried this separately on another L3 image, and had no issues.
This issue is resolved. The problem was with the gateway configuration of the host connected to the Nexus.
liviu.gheorghe
I just tested it in CML and it works as it should. Can you share the config of your Nexus?
Regards, LG
*** Please Rate All Helpful Responses ***
!Command: show running-config
!Running configuration last done at: Tue Mar 26 20:51:20 2024
!Time: Tue Mar 26 22:08:45 2024
version 10.3(1) Bios:version
hostname Core1
vdc Core1 id 1
limit-resource vlan minimum 16 maximum 4094
limit-resource vrf minimum 2 maximum 4096
limit-resource port-channel minimum 0 maximum 511
limit-resource m4route-mem minimum 58 maximum 58
limit-resource m6route-mem minimum 8 maximum 8
feature interface-vlan
feature lacp
no password strength-check
username admin password 5 $5$FHHHLG$t3HL9jg7M1U.KD6WIl8b7xlhDFR32Ll1kcfy7fpCQOD
role network-admin
username cisco password 5 $5$IMAJFK$lfMzZzlUuJqWrjcGBPIpuaVSqzCUVHsPGbp/2nKKnP2
role network-admin
username cisco passphrase lifetime 99999 warntime 14 gracetime 3
ip domain-lookup
snmp-server user admin network-admin auth md5 482A81F671C51A294B3FB0B72BDACD6F14
46 priv aes-128 497687A1509702305266F78B36E5B56F0459 localizedV2key
snmp-server user cisco network-admin auth md5 37479DE042F734197B08CFF125CEB37C5C
4A priv aes-128 204FF4D63683394D3711D3AB6B88BC7D5C32 localizedV2key
rmon event 1 log trap public description FATAL(1) owner PMON@FATAL
rmon event 2 log trap public description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 log trap public description ERROR(3) owner PMON@ERROR
rmon event 4 log trap public description WARNING(4) owner PMON@WARNING
rmon event 5 log trap public description INFORMATION(5) owner PMON@INFO
vlan 1-3
vrf context management
interface Vlan1
interface Vlan2
no shutdown
interface Vlan3
no shutdown
interface Ethernet1/3
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
interface Ethernet1/32
interface Ethernet1/33
interface Ethernet1/34
interface Ethernet1/35
interface Ethernet1/36
interface Ethernet1/37
interface Ethernet1/38
interface Ethernet1/39
interface Ethernet1/40
interface Ethernet1/41
interface Ethernet1/42
interface Ethernet1/43
interface Ethernet1/44
interface Ethernet1/45
interface Ethernet1/46
interface Ethernet1/47
interface Ethernet1/48
interface Ethernet1/49
interface Ethernet1/50
interface Ethernet1/51
interface Ethernet1/52
interface Ethernet1/53
interface Ethernet1/54
interface Ethernet1/55
interface Ethernet1/56
interface Ethernet1/57
interface Ethernet1/58
interface Ethernet1/59
interface Ethernet1/60
interface Ethernet1/61
interface Ethernet1/62
interface Ethernet1/63
interface Ethernet1/64
interface mgmt0
vrf member management
icam monitor scale
line console
line vty
boot nxos bootflash:/nxos64-cs.10.3.1.F.bin
