CSPC and Cisco Umbrella connectivity issues
bwyncoll
I am trying to get CSPC ( SMart Collector Platform ) version 2.10 working with Cisco Umbrella as we have moved from a legacy Bluecoat proxy solution. no matter what i try it wont work, i have used connectivity direct mode with native linux proxy config set for both shell and non shell , used all iterations of the umbrella proxy url we have set on other linux devices with no problems within cspc via cli using the conf commands. i have also set the proxy config manually editing /etc/scproxyconf file and all i can get working is curl , but the cspc doesnt show anything hitting Umbrella at all ever
any help would be greatly appreciated as its driving me nuts
bwyncoll
solved this , need to convert the default CA cert for Umbrella from .cer to .crt format using openssl all explained in this link if it helps anyone else :
https://danielmartins.page/posts/installing-cisco-umbrella-root-ca-for-linux/
