Webex Problem - Repeating beep that is not a notification
cathie p
During every Webex call I hear a rhythmic beep that continues until the end of the call. It is not a notification sound as it is unrelated to attendees entering or leaving the call or muting/unmuting etc. It is very loud and annoying and none of the settings seem to address this issue.
helpcenterus
@cathie p to try troubleshoot this problem, you might want to check if any other applications or devices running concurrently are causing interference. Additionally, ensure that your audio drivers are up-to-date and compatible with Webex. If the issue persists, you could try adjusting your microphone and speaker settings within the Webex app, as sometimes conflicts in these configurations may lead to unexpected sounds.
cathie p
I will try your suggestions and get back to you. Thanks for your help.
helpcenterus
happy to help you
