Help in designing a kron to shutdown an interface
jomo frank
Hello Expert
I tried run the following Kron but I am unsuccessful .
kron policy-list restart-interface
cli enable
cli config t
cli int FastEthernet0/1
cli shutdown
kron occurrence restart-interface at 10:45 recurring
i humbly request some guidance to run same successfully.
2 Accepted Solutions
cli enable
cli config t
cli shutdown
exit
below runs at 10:45
BB
At 10:45 it runs every day
here is a good explanation :
https://crontab.guru/#45_10_*_*_*
every 2 hours as below :
https://crontab.guru/every-2-hours
BB
12 Replies 12
balaji.bandi
not sure we understand this, Do you want @10:45am shutdown and no shutdown interface fas 0/1 ?
BB
hello Balaji,
The restart-inferface is just the name I should have use a different name.
I just need to shutdown  the interface at 10.45 am this exercise is just a test .
I
cli enable
cli config t
cli shutdown
exit
below runs at 10:45
BB
Good Day,
I tried as per your suggestion but nothing happened
Unsure what a am doing wrong?
cli enable
cli config t
cli shutdown
Thank you
Do you still have an issue ? kron runs @104am
BB
Hello Balaji,
The kron did not run the interface is still up.
Looks there is Limitation in kron, its not excuting what expected, instead you can use EEM as below :
event manager applet shut-interface
event timer cron name shutdown-interface-schedule cron-entry "45 10 * * *"
action 01.0 cli command "enable"
action 02.0 cli command "config t"
action 03.0 cli command "interface FastEthernet0/1"
action 04.0 cli command "shutdown"
action 05.0 syslog msg "Interfeace FastEthernet0/1 has been shutdown by EEM applet"
end
Tested and working as below in my LAB (just used time 16:46)
BB
Hello
I will try the new method but I am trying to understand the event time line
for example if you need an event to happen ever 60 minutes (1 hr) how do amend the event timer line to do so.
Hello Expert,
The event manager work perfect.
Could you please modify the event manager to restart the interface very 120 minutes (2 hrs).
BB
Hello Bal,
Thank you for all the assistance.
dude i had to sign in just to thumbs up your post if I could give you 100 thumbs up I would thanks a million!
