Help Needed For Cisco 340 Edge
Not 100% sure If I am putting this in the right place. I have been trying to figure out how to change the admin password on cisco 340 edge so I can install a different OS. I need to enter the BIOS settings and change the admin password and turn off safe boot (If that's a thing). The manual is not very helpful. I will attach the manual. Any help would be very useful thank you.
Do you know what the default root and reimage passwords are? Thank you for your help.
The default login credentials are found in the link I've posted.
