How to connect using console(serial port) between Ansible to Cisco?
Bruen11
I'm using Ansible for automation network devices.
After cisco switch factory reset, I don't know that how to connect cisco console port instead of ssh.
I want to know way only serial(console port) connection that ansible connects to brand new cisco devices without setting IP for ssh connection.
ToysRUs Credit Card
johnd2310
Level 8
Level 8
You need a way of getting an ip address on the switch before ansible can get to it. I don't think you can have ansible connect to the console.
You could try testing a terminal server with reverse telnet, maybe this will allow you to connect
John
**Please rate posts you find helpful**
