student requesting for Cisco packet tracer configuration assignment
Arn2x
Can anyone here by any chance would be able help me with my cisco packet tracer configuration assignment?
i can upload the packet tracer file
Thanks in advance
46 Replies 46
Ok Thank you so much Flavio
Hi Flavio,
can you please check why i cannot ping HR PC trying to ping from marketing and tech support
Arnold
Are you sure. I can ping from my file just fine from HR to Marketing.
hr to marketing is ok pinging, but pingimg from marketing and tech support pc i cannot ping HR and cannot telnet router 0 1 2?
there was an error on the ACL
It should be
access-list 100 permit icmp any any echo-reply
access-list 100 deny ip any 192.168.3.16 0.0.0.15
access-list 100 permit ip any any
I change the ACL and it seems fine now. Take a look
Hi Flavio,
I was trying to telnet router 0 1 and 2 but i cannot telnet, i tried to set the vty 04 password cisco but still telnet is not working
can you please check?
Thank you
Run this config on the router
line vty 0 4
 transport input all
login local
Then, create username and password
username user privilege 15 password cisco
enable secret cisco
ok thank you
Can you telnet now?
yes i can telnet now thanks for giving the telnet commands
but what is the command if i want only the VLAN 40 IT pc's can only telnet router 0?
Replied  below
Hi Flavio,
What is the command on Router 0 if i want only VLAN40 IT pc's can telnet router 0 but no other network or vlan can telnet router 0?
You can create an access-list permiting only IT PC
access-list 101 permit tcp 192.168.3.16 0.0.0.15 any eq telnet
Then, you apply to the line vty 0 4
line vty 0 4
access-class 101 in
The router will allow only telnet from IT network.
Thank you so much i appreciate your help
