student requesting for Cisco packet tracer configuration assignment
Arn2x
Can anyone here by any chance would be able help me with my cisco packet tracer configuration assignment?
i can upload the packet tracer file
Thanks in advance
46 Replies 46
Here we go
Arn2x
Thank you so much! I appreciate your help.
You may need to label the vlans and make some change your teacher may ask but the overall idea is there.
Hi Flavio, can you please configure the dhcp? i cannot ping each other seems like dhcp is not working
teacher said create extended ACL so that no client can ping IT vlan pc's but IT  pc's can ping all clients
Arn2x
Hi Flavio,
I am trying to configure DHCP pool on Router 3 and 4 but it is not working can you please help me configure dhcp
attached is the packet tracer file
Thanks in advance
It is all there. DHCP on routers, ACL. It is all working.
What might happen is when you save my file and open in your PC, the pkt file may not keep everything up.
 Basically you need to check all the PCs and see if they got IP address. If not, you need to force them to do so.
 You can use the commamd ipconfig /release and ipconfig /renew, this command you run on each PC
change it to DHCP if required
Hi Flavio,
I tried to force on the command prompt and still getting dhcp request failed, on the desktop settings ip configuration it is set to dhcp, i have attached the packet tracer file, can you please check? Thank you
Hi @Arn2x , sorry. The way I built the Access List it was also blocking the DHCP traffic.  It might work now.
Let me know
ok thank you flavio
Hi Flavio,
Can you please help me with my new assignment?
i already created the network topology on packet tracer,
i will attached the pkt file and the assignment configuration instructions
Thank you in advance
Hey @Arn2x , of course. Let me take a look
wait i will send you my updated packet tracer file, the labels on the switches is not yet updated on that pkt file i sent to you
attached is my updated packet tracer file
Hi @Arn2x
 I worked on the first file you attached.
I believe 95% is there, you may need to check a few things only.
Let me know if you need any help
