Terminating Putty SSH sesion with sh tech-sup output
Erdal_sahin
Hello community,
is there a way to terminate a Putty SSH session that outputs to the console with a sh tech-sup output loop. The device is a Nexus 7 k
best regards
Erdal_sahin
Hello balaji bandi,
thanks for your answer.
but I don't see in the link how I can interrupt the output loop. Do I have to do via console port on the machine ? if so what command do I need there.
best regards
You want to see the terminal output in the ssh session (maybe I miss understanding first place)
#terminal monitor
BB
again the problem, there was a show tech-supp command set, the whole thing is output at the terminal in a loop because the command was provided with a variable. the output at the Cosole ran 2 days can not you interrupt something like that ? like Kill pid or the same ?
best regards
sahin
