Transceiver speed does not match the speed configured on the port
YB2828
- I have a cisco Nexus9000 C92300YC Chassis with two supported 10G optics for it.
- When inserting a 10G optic in one of the ports, it keeps showing the "Transceiver speed does not match the speed configured on the port" error message.
- But the same optic works just fine on another port with same configurations.
interface Ethernet1/5
switchport mode trunk
switchport trunk native vlan 40
mtu 9216
Nexus9k-IPEX# sh int ethernet 1/5
Ethernet1/5 is down (Transceiver speed does not match the speed configured on th
e port)
admin state is up, Dedicated Interface
Hardware: 1000/10000/25000 Ethernet, address: f80f.6fe3.a972 (bia f80f.6fe3.a9
72)
Description:
MTU 9216 bytes, BW 25000000 Kbit , DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is trunk
auto-duplex, auto-speed, media type is 10G
Beacon is turned off
Auto-Negotiation is turned on FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
admin fec state is auto, oper fec state is auto
Last link flapped never
0 interface resets
Load-Interval #1: 30 seconds
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
Load-Interval #2: 5 minute (300 seconds)
300 seconds input rate 0 bits/sec, 0 packets/sec
300 seconds output rate 0 bits/sec, 0 packets/sec
RX
4 unicast packets 0 multicast packets 0 broadcast packets
4 input packets 2452 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
4 output packets 2452 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
Ethernet1/3
transceiver is present
type is 10Gbase-SR
name is CISCO-AVAGO
part number is SFBR-7700SDZ-CS2
revision is B5
serial number is AGD1330321U
nominal bitrate is 10300 MBit/sec
Link length supported for 50/125um OM2 fiber is 82 m
Link length supported for 62.5/125um fiber is 26 m
Link length supported for 50/125um OM3 fiber is 300 m
cisco id is 3
cisco extended id number is 4
cisco part number is 10-2415-02
cisco product id is SFP-10G-SR
cisco version id is V02
Ethernet1/4
transceiver is not present
Ethernet1/5
type is 10Gbase-SR
name is CISCO-FINISAR
part number is FTLX8571D3BCL-CS
revision is D
serial number is FNS12190KJQ
cisco id is 3
0 Replies 0
