Upgrade Cisco Switch iso via console cable
Faresnani
I have this Cisco fiber switch (catalyst WS-C3750G-12S )and I want to upgrade the iso it has all fiber port and there's no USB port, how can I upgrade the switch only using a console cable
I have an iso file on my laptop and I already installed tftpd64
 I am assuming that you dont have any GBIC over there?
The option I see is via xmodem but, man, this is going to take a while to transfer the IOS. I did it some time ago and it took a long time.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-1_14_ea1/configuration/guide/3750scg/swtrbl.html#wp1099467
yes I don't have GBIC
both Switches  in Stack mode
can I upgrade the fiber Switch from the Lan Switch using Stack?
It is possible. But, if fiber switch is the master, you need to change it.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/64898-upgrade-3750-stack.html#steps
