upgrading power sequencer on 5548UP Switch
from88
Level 4
Level 4
hello!
The situation is that i've 5548UP Switch with very old software version:
Software
BIOS: version 3.6.0
loader: version N/Acis
kickstart: version 7.0(5)N1(1)
system: version 7.0(5)N1(1)
Power Sequencer Firmware:
Module 1: version v1.0
Module 2: version v0.0
Module 3: version v5.0
Microcontroller Firmware: version v1.2.0.1
SFP uC: Module 1: v1.0.0.0
QSFP uC: Module not detected
BIOS compile time: 05/09/2012
kickstart image file is: bootflash:///n5000-uk9-kickstart.7.0.5.N1.1.bin
kickstart compile time: 10/29/2014 22:00:00 [10/30/2014 07:30:37]
system image file is: bootflash:///n5000-uk9.7.0.5.N1.1.bin
system compile time: 10/29/2014 22:00:00 [10/30/2014 12:45:59
I don't know how it happened but seems like this switch power sequencer version is older than it should be by existing 7.0(5)N1(1). I know that because other switch in a pair has newer Power sequencer version with the same software version. I think it could by because someone installed this device in a wrong way - for example not with install all, but with setting the boot variables and restarting the switch.
So, i have googled the right path to upgrade the software, the next step will be version 7.1.4.N1.1, and by doing show install all impact I see:
Images will be upgraded according to following table:
Module             Image         Running-Version             New-Version  Upg-Required
     1            system             7.0(5)N1(1)             7.1(4)N1(1)           yes
     1         kickstart             7.0(5)N1(1)             7.1(4)N1(1)           yes
     1              bios      v3.6.0(05/09/2012)      v3.6.0(05/09/2012)            no
     1         power-seq                    v1.0                    v3.0           yes
     1            SFP-uC                v1.0.0.0                v1.0.0.0            no
     2         power-seq                    v0.0                    v1.0           yes
     3         power-seq                    v5.0                    v5.0            no
   103             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   104             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   106             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   109             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   110             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   113             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   126             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   128             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   129             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   130             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   134             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   150             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   151             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   154             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
   155             fexth             7.0(5)N1(1)             7.1(4)N1(1)           yes
     1   microcontroller                v1.2.0.1                v1.2.0.1            no
So by looking at this everything should be ok, i will upgrade the switch, after that i will do the reload with power-cycle option.
Is there anything i should take into action more ? It's some type of not ordinary situation because the current software (i guess) was installed not in the right way. Or maybe i would need to reinstall the current  one 7.0(5)N1(1) ?
balaji.bandi
Note After a successful power sequence upgrade, you must switch off the power to the system and then power it up.
reference :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5600/sw/upgrade/710_N1_1a/n5600_upgrade_downgrade_710_n1_1a.html#pgfId-781686
BB
thanks, as i know for the power-sequences upgrade it's enpugh to do "reload power-cycle".
