Want Help in my university project
Can any one help me for the task below
Task details:
You are tasked with designing, installing, and configuring a network for any organization (i.e. school, university, college) with the following requirements:
  • The network should support a main campus (head office) and a minimum of three remote campuses (branch offices)
  •  Use leased lines for WAN connectivity between campuses, implemented with routers.
  • Configure OSPF (Open Shortest Path First) for dynamic routing across the network
  •   At the main campus, implement three VLANs:
  1. VLAN 10: Staff
  2. VLAN 20: Faculty
  3. VLAN 30: Students
  • Implement centralized DHCP servers to assign IP addresses to devices across all campuses dynamically. Ensure DHCP Relay is configured for branch offices.
  • Install and configure a Cisco firewall at the head office
@muhammad-yazan1224
 Sure you are going to be helped here. But, you need to get busy and do something. I am assuming you are going to do it in PacketTracer. What you have done so far?
Hello @muhammad-yazan1224 ,
share your PacketTracer file so we can have a look and give you some pointers.
Regards, LG
*** Please Rate All Helpful Responses ***
