Web UI interface showing up incomplete
Aria
Hi.
I try to open web interface for ISR 1100 cisco router but it is showing incomplete. I don't have the configuration rebon and all I have in navigation menu is Dashboard and Monitoring.
I shared the screenshot.
Aria
16 Replies 16
follow below thread :
https://community.cisco.com/t5/network-management/correct-procedure-for-default-factory-reset-of-cisco-c1111-4p/td-p/4394163
If you doing factory reset, correct your config register as i mentioned one of the post above.
EDIT :
had one of the device in my lab, just booted and simple basic setup i am able to get through and all menu visible :
#show run | in http
ip http server
ip http authentication local
ip http secure-server
destination transport-method http
#show run | in username
username admin privilege 15 password 0 admin123
BB
Hi. Thanks. It seems like the ISR1100-4G boot from controller managed mode and I cannot switch to autonomous mode.
The reason I cannot see the full menu is this. What is your opinion?
